5.0 won't run
Old 08-16-2012, 10:40 PM
indianajim
indianajim's Avatar
Default 5.0 won't run
I have a 5.0 HO that won't stay running and is stumping me.
This engine stopped running over a year ago and sat the whole time.
Recently we brought it up to top-dead-center and got everything firing fine. It was then running fine for about a week. I put gas treatment and filed it with new high octane gas. Then the motor just started running bad and eventually stopped starting completely.
I tried a new(different) computer, changed the fuel filter, and we have spark.
We checked fuel pressure from the tank (filter area) and at the engine area - Good but possibly not enough pressure?
It has spark and will momentarily start using starting fluid at the intake but that's it.
Our only thought is that it is in the fuel delivery. Any ideas to check?
Any help would be great.
Thanks,
Jim
indianajim is offline
Old 08-17-2012, 01:27 AM
rydinturbo
rydinturbo's Avatar
what was the fuel pressure? how do the plugs look? check for codes, vaccum leaks ect. does it just crank over
rydinturbo is offline
Old 08-17-2012, 09:08 PM
indianajim
indianajim's Avatar
Plugs and wires are new as is the rotor/cap.
It does just crank over.
We'll need to check fuel pressure with a gauge. We only looked for fuel movement visually.
Thanks
Old 08-18-2012, 11:29 AM
Duncan_GT
Duncan_GT's Avatar
It sounds like fuel pressure. Although I'm not sure why it would lose pressure over a week's period
Duncan_GT is offline
Old 08-19-2012, 03:06 PM
Bubba 95SN
Bubba 95SN's Avatar
Put gauge on fuel rail, post results.....
Bubba 95SN is offline
Old 08-19-2012, 06:56 PM
2011scgt
2011scgt's Avatar
these pumps can just take a dump with no warning
2011scgt is offline
Old 08-23-2012, 09:01 PM
indianajim
indianajim's Avatar
Just to let you know, no codes came up when checked. That was the real stumper as to why it isn't running.
I'll soon try the fuel pressure with a gauge.
Old 08-24-2012, 01:57 PM
87 T TOP GT302
87 T TOP GT302's Avatar
Just a thought but have you checked you fuel lines?
87 T TOP GT302 is offline
Old 09-15-2012, 04:33 PM
indianajim
indianajim's Avatar
Default Still not running
Finally got back to the fuel test and there is ample pressure (38lbs). Also replaced the fuel regulator with no changes.
Just a follow-up. It was running for a while and started to sputter and bog down. After parking it, it never started again.
Checked the codes and none show. Checked vacume lines - no problem.
Still completely stumped. Any ideas would be greatly appreciated.
Thanks.
Old 09-20-2012, 08:58 PM
indianajim
indianajim's Avatar
Default Fuel injectors?
I was told by someone that it may be the fuel injectors.
Any thoughts?
Thanks
Quick Reply: 5.0 won't run
