Scratching Sound with People in Back Seat
Old 11-02-2012, 08:55 PM
getoutofmyinternet
getoutofmyinternet's Avatar
Default Scratching Sound with People in Back Seat
I have a 1995 Mustang 5.0 with 175xxx miles and a rebuilt tranny.
Whenever I have people in my back seat, I hear a scratching noise coming from the rear when I take off. The problem gets worse the more weight in the back.
I have done the bouncing shock tests, and the shocks definitely need replacement. But my question is, while replacing the shocks alleviate this problem?
I am also going to replace the differential, as it is making noise humming noises in the rear.
getoutofmyinternet is offline
Old 11-02-2012, 10:50 PM
94redGTConv
94redGTConv's Avatar
Does it sound like its bottoming out? if you don't know what that sounds like it could be your rubbing your fender wells
Posted from MustangForums.com App for Android
94redGTConv is offline
Old 11-03-2012, 11:15 AM
getoutofmyinternet
I would say it is most likely something rubbing on the wheel well since thats where the sound seems to be coming from. Do you think replacing shocks would stop this?
Old 11-04-2012, 09:16 AM
94redGTConv
Probably, but you also need to replace your bump stops of you've been bottoming out a lot, but yeah start at springs
Old 11-06-2012, 08:32 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
No...start with replacing the shocks....then tell the fat people to get out of the back of your car....then get some lowering springs and replace the pinion snubber that goes with it lol..
What size tire are you running? There is really no reason why you should have tire rub in the rear unless stuff is terrible worn or there is ALOT of weight in your body style...
projectresto83 is offline
Old 11-08-2012, 07:25 AM
duncan01
duncan01's Avatar
ad adjustable shocks and work from the stiffest setting down to where you get the nicest ride without bottoming. Look at your tires and see if your cutting into them. You may have to do some massage work in you inner fender wells depending on you tire size.
duncan01 is offline
Old 11-08-2012, 08:54 AM
89fiveeight
89fiveeight's Avatar
And lay off the fat girls.
89fiveeight is offline
Old 11-09-2012, 09:36 AM
95 BLOWN GT
95 BLOWN GT's Avatar
Talking
+1.lol rear seat delete should solve your problem....then you will not have to replace any
suspension parts.
95 BLOWN GT is offline
Old 11-09-2012, 11:08 AM
getoutofmyinternet
It's not the fat people LOL
it happens even with my 110 pound girlfriend in the back
Old 11-09-2012, 11:09 AM
getoutofmyinternet
So what i'm planning to do is replace my shocks and springs. Hopefully this with stop the grinding noise
Quick Reply: Scratching Sound with People in Back Seat
