clutch cable
clutch cable
Hey guys well yesterday my clutch cable ripped in traffic. I had just replaced it about 4-5 months ago with a cheapy from autozone. It was the non adjustable cable with an adjuster at the firewall. Fixed it right away with another cheapy after i got it towed ( thanks to progressive road side) home. My question is if it ripped at the firewall, what would cause this.. Bad cable, cheap?
Yep. You can get a Ford cable from MM also. You should still be able to get a 04 cable from Ford. It will wok you just have to modify where it goes into the firewall adjuster and the bracket at the frame doesnt work.
i guess so.. get the cable from authorized dealer of ford... even i had cable problem with my ford falcon.. actually this cheap cables are not good at all.. its just wastage of money nothing else.. i would love to suggest you to get company one.. and if you face problem in changing this cable you can follow the below link.. i had problem regarding changing this cable and got help from this site..
falcon workshop
falcon workshop
best cable/quadrant
to the o.p., i just went threw that same az pos cable. i did my research and maximum motorsports cable is the best you can get,also pair that with there quadrant[it's wayyyy better than all the rest belive me]. my cable from steeda[also got there quad and adjuster] snapped at the quad because there quad sucks,its angle is all wrong. i wish i had gone with MM from the start,good luck to you and that fine fox of yours..
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
