low idle/crappy after intake install
Old 12-30-2012, 12:35 AM
Js88lx
Js88lx's Avatar
Default low idle/crappy after intake install
Well i will start a new thread specifically for my problem. I just installed the BBK ssi intake and now when i turn my car on it will idle fine with a little bit of studder and after one min (cold or hot) it will lower idle to 600 and idles crappy. I set the timming at 14 if it helps. Also i can smell the gas in my exhaust, almost makes me tear up. Once i rev the car it revs nice and strong. It also hesitates when i give it gas slowly between idle and 2k rpm's. Would the tps cause this. I basically just swapped the entire intakes with sensors from another car. Help Guys.., PLease!
Js88lx is offline
Old 12-31-2012, 04:05 PM
Mike T
Mike T's Avatar
You might want to swap your IAC from the other intake.
Mike T is offline
Old 12-31-2012, 06:28 PM
Js88lx
Js88lx's Avatar
I did that today.., i actually swapped the entire throttle body to the stock one that had the old iac but no luck.
I tried reseting the base idle but i think i failed as it still idles low but i turn up the throttle screw so idle is better.
I also checked the tps volts and did adjust correctly as it did need it. Its running better now but not as smooth as it did before the install. When cold i have to give it a little gas to get the idle goin. My fingers hurt.. LOL
Js88lx is offline
Old 12-31-2012, 08:03 PM
94redGTConv
94redGTConv's Avatar
check your map
Posted from MustangForums.com App for Android
94redGTConv is offline
Old 12-31-2012, 08:23 PM
Js88lx
Js88lx's Avatar
Do you mean the BAP sensor? I have a MAF car. Bap sensor is plugged for MAF cars.
Js88lx is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
MXBT187
08-20-2015 02:36 AM
Quick Reply: low idle/crappy after intake install
