transmission
Old 02-23-2013, 06:41 PM
gyouska
gyouska's Avatar
Default transmission
how can I clean the old gasket off my valve body plate I have been picking at it with a razor blade but it getting to the point where the blade will do more damage than good if I continue.
gyouska is offline
Old 02-23-2013, 07:35 PM
Mike T
Mike T's Avatar
There's no easy way to do it. Don't use any thing sharp. A dull putty knife would be what I would use.
Mike T is offline
Old 02-23-2013, 11:42 PM
tinman
tinman's Avatar
Aerosol cans of carb cleaner.
You don't want to scratch that part....
tinman is offline
Old 02-24-2013, 01:48 AM
dawson1112
dawson1112's Avatar
Scotch-Brite Roloc Surface Conditioning Discs made by 3m if you have a die grinder or even a fast spinning drill moter. They work really well for removing old gasket material , made just for this purpose and will not remove any metal. They leave a very nice clean surface . If you don't have a die grinder you can just use the scotch brite pads that you would normally use for scouring pots and pans with but youll have to use a lot of elbow greese lol .
dawson1112 is offline
Old 02-24-2013, 10:59 AM
gyouska
gyouska's Avatar
ok i will try that most of it is off just some of the edge spots are being stubborn.
gyouska is offline
Old 02-24-2013, 11:44 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
do not use those on the valve body!!!, irregardless of what anyone says or will say, no matter what grit is used they score the surface/etch the surface, I don't even use them on aluminum heads anymore, just a razor blade, gasket remover spray in extreme cases and patience, valvebody surface is critical to keep the surface true as such was machined and not induce an uneven/or scored surface one bit.
mjr46 is offline
Old 02-24-2013, 10:57 PM
tinman
tinman's Avatar
^^^^^^^^^^And thats the truth BTW^^^^^^^^^^^^
tinman is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: transmission
