Fuel pressure regulator issue
Old 04-21-2013, 02:10 PM
Black90notch
Black90notch's Avatar
Default Fuel pressure regulator issue
Ok so I'm pretty sure my regulator is shot. Can't get into it at all without it choking up and supudering. Feels like it wants to stall at idol.
H/c/I 5spd 255 pump with 24# injectors. Ive looked into getting a new regulator but don't know what psi I need to be at. Some are at 45, other adj from 35-65.
Any input would be great
Black90notch is offline
Old 04-21-2013, 02:39 PM
mrz2207
mrz2207's Avatar
Should be about 42psi with vacuum unhooked. 38-39 psi are also good to if you get that. it could be a bad fuel pump if you get low pressures and bad regulator if you get too high.
mrz2207 is offline
StalkerGT
09-25-2015 02:41 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
zanemoseley
09-06-2015 12:58 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Fuel pressure regulator issue
