Tire touching backside of wheel well
Old 05-04-2013, 10:41 AM
pedalhappy
pedalhappy's Avatar
Default Tire touching backside of wheel well
Looks like the tire is a bit close to the wheel well and when I bought the car it had a rebuilt title but i dont think it was completely done or done right. What would cause this? Thanks guys
pedalhappy is offline
Old 05-04-2013, 03:51 PM
Duncan_GT
Duncan_GT's Avatar
Duncan_GT is offline
Old 05-04-2013, 04:23 PM
dawson1112
dawson1112's Avatar
And which tire???
dawson1112 is offline
Old 05-04-2013, 08:07 PM
pedalhappy
pedalhappy's Avatar
front right tire and make it worth something im in afghan so i cant get pics lol
Old 05-04-2013, 08:35 PM
dawson1112
dawson1112's Avatar
That happens when someone ditches the car hard or hits something hard like a curb . Possibly a bent control arm or k member is bent or shoved back
Old 05-04-2013, 08:41 PM
dawson1112
dawson1112's Avatar
Does the car pull to that side ??
Old 05-05-2013, 03:29 AM
pedalhappy
pedalhappy's Avatar
Not sure, just bought it for 1900 with no trans. \i havent even heard it run but my dad has. So if anything i paid 1900 for a motor but still. I was thinking possinbly a bent swing arm or something. How would I be able to find out for sure what the cause is? Just so I can guide him on what to do. I have about 1300 to spend on a T-5 and fix whatever else is wrong with it. Where can I find a tubular K member? If I am going to replace stuff might as well upgrade right?
Old 05-05-2013, 06:21 AM
dawson1112
dawson1112's Avatar
Im guessing it was involved some kind of front end collision at some point . This could have been the result of running over a curb as well or and hard jolt to the front end. Most of the time the k member bends where the control arms connect to it, however being that the car came with no trans, I would try to find out why the trans was removed, If the k member was shoved back it could have caused the engine to shift cockeyed in a violent enough manner to bind up the drive train and damage the trans. If the k member was replaced after a collision it may not be aligned correctly , there is a lot of measuring that goes into getting the k member in the car so that every thing is square. It cant just be bolted up and ready to roll .
To check if the k member is square you need a tape measure and a couple plumb bobs . Maximum Motorsports has a pretty good right up of how to square up the front k member , they are actually showing the install of one of there aftermarket k members but you can get a pretty good Idea of how alignment of the k member is accomplished ....
http://www.mustang50magazine.com/how...orts_k_member/
Old 05-05-2013, 07:44 AM
pedalhappy
pedalhappy's Avatar
cool thanks, ill have em look into it. Also the trans blew 3rd... typical T-5.
Old 05-05-2013, 07:52 AM
dawson1112
dawson1112's Avatar
Your welcome brother , good luck with the car, and come home safe man....
Quick Reply: Tire touching backside of wheel well
