99 rear end into a 94 both gts
Old 05-05-2013, 10:43 PM
Sn5.0
Sn5.0's Avatar
Default 99 rear end into a 94 both gts
I've been trying to find just a simple answer to this question. If I take the entire 8.8 real axle from wheel to wheel out of a 99 mustang gt can I roll it right under my 94 gt and blot it in? I plan to build it first just want to make sure it's a direct bolt in before I buy the newer rear end. Thank you for any help. Also another question to go with, will the drive shaft bolt up using the same u-joint?
Sn5.0 is offline
Old 05-05-2013, 11:13 PM
pedalhappy
pedalhappy's Avatar
I am pretty sure it is if all the suspension is the same
pedalhappy is offline
mtgldr
02-03-2024 09:00 PM
GimpyHSHS
09-18-2015 12:27 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
Quick Reply: 99 rear end into a 94 both gts
