Control arms
Old 07-09-2013, 03:11 PM
darkmach1
darkmach1's Avatar
Consider the possibility that you might need torque box work on these old foxes when you're getting ready to do uppers. BMR adjustable uppers and non adjustable lowers, love it.
darkmach1 is offline
Old 07-09-2013, 03:33 PM
bluebeastsrt
bluebeastsrt's Avatar
I went with UPR stuff. High quality uppers & lowers with torque boxes should handle anything you throw at them.
bluebeastsrt is offline
Old 07-09-2013, 04:36 PM
darkmach1
darkmach1's Avatar
^i've got the UPR torque box kit, good ****.
Old 07-10-2013, 04:44 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
^^the good stuff!
UPRSharad is offline
Old 07-13-2013, 02:36 PM
Daniel Bente
Daniel Bente's Avatar
I'd go with a set of matching uppers and lowers. I DO NOT recommend any arms made from square tubing with "hard" square mounting brackets on the ends (they tend to crack more than round tubes). Unless you go with bearing mounted (spherical rod ends) you will always run into binding upon suspension flex (unrated spring action). It is this flex/bind that causes structural failures in the control arms. Another solution to this bind issue is to grind off just enough of the bushing and metal insert ends to prevent this bind from occurring.
Daniel Bente is offline
mrtrodonet
09-19-2020 03:12 PM
UrS4
10-03-2015 06:23 AM
breaking
10-02-2015 01:27 PM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Control arms
