Exhaust Hangers
Exhaust Hangers
How the hell do you remove the exhaust hangers from the rubber grommets under the car? I've cut the tail pipe off so the only thing holding it still are the hangers, but I'll be damned if I can get them out of the rubber. I'm about ready to just cut the rubber but if there's a way to save them, I'd prefer that
I always use a screw driver on them and stretch it out a bit and squirt some oil or wd40 in it to help lube it up , they can be a pita to get out. I have found it easier if you try to get the hanger off the car and leave the rubber on the tail pipe because the barb doesn't move on the car and you can wedge something in there and pry it off.
I have been known to get mad and cut em though too lol
Lube them with something, almost anything liquid, and then a big pry bar (or a 2x4, or whatever). Pry against anything handy that will help push them out.... I have also sometimes like Dawson said, unbolted the hangar, and left them on the barb. Whatever works!
The passenger side I will need to replace. The rubber is sagging and all distorted/stretched/cracked.
I am thinking about running side pipes though. Haven't really made up my mind. I don't think hangers are used for them, could be wrong
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
