Winter Build... Thoughts?
Old 11-12-2013, 09:19 PM
Ineedmorespeed
Ineedmorespeed's Avatar
Default Winter Build... Thoughts?
95 GT 5.0 5speed
current mods -
BBK C.A.I.
BBK Headers
No Cats
Off road H pipe
Smog Pump deleted
shorter belt
Msd dis/cap/rotor
BBK racing wires
70mm Throttle body
3.73 gears
I plan on upgrading some stuff this winter
upgrades will include
GT40 heads
-probably changing to 1.7rr
GT40 upper/lower intake
thinking a B cam or something close
-do I need different push rods?
85mm Mass Air
- with these mods will i need to ugrade
my fuel injectors to 24#
Hi Volume water pump
Hi Volume Oil pump
How will all those work?
Will I need anything else?
Ineedmorespeed is offline
Old 11-12-2013, 11:33 PM
tinman
tinman's Avatar
If you are changing heads and rocker arms I'd say that it will probably need a set of pushrods too.......
tinman is offline
Old 11-13-2013, 12:28 AM
bluebeastsrt
bluebeastsrt's Avatar
Since your going to the trouble of removing the top end. Id use better heads and intake.
bluebeastsrt is offline
Old 11-13-2013, 06:37 AM
9redfox3
9redfox3's Avatar
Originally Posted by bluebeastsrt
[B]Since your going to the trouble of removing the top end. Id use better heads and intake.[B]
It's all about the $$ ....
I didn't change mine pushrods and i'm running a similar set up and had no issues at all but left the stock HO cam in car ? I Never changed my stock oil pump or water pump... Go with felpro gaskets !
Good luck with build heads along should give you another 40 more hp or so no need to change out the 19lb injectors good up to 300 hp or so just send them out to here and get rebuilt this is where i sent my they did a good job on them !
http://accurateis.com/store/index.php
9redfox3 is offline
Old 11-13-2013, 07:52 AM
Ineedmorespeed
Its definitely all about the money.. I had a few of the items already and my buddy has a few from a project he stopped working on, other wise I'd probably go with better heads and intake.. So I plan on putting this stuff on over the winter just to give the car a lil more. I also just picked up a 351 block for cheap and plan to slowly build that motor.
Old 11-13-2013, 12:29 PM
Duncan_GT
Duncan_GT's Avatar
Changing out your injectors will give you room to grow in the future. If you are set on replacing the water and oil pumps, just get stock replacements. No need for hi volume
Duncan_GT is offline
Old 11-13-2013, 03:47 PM
9redfox3
9redfox3's Avatar
True but I wouldn't waste my money on 24lb injectors for what he wants to do at this point....If that's the case 30 or 36's ?
9redfox3 is offline
Old 11-13-2013, 05:15 PM
Duncan_GT
Duncan_GT's Avatar
I'll sell him my 42's. It was just a suggestion I see most people do, I personally wouldn't do it if I already had the 19's.
bradleyb
11-27-2015 07:50 PM
Sixer4Life
10-12-2015 04:26 AM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Winter Build... Thoughts?
