90 5.0 erratic spark
Old 12-10-2013, 09:50 AM
Sally91
Sally91's Avatar
Default 90 5.0 erratic spark
I have a 1990 5.0 mustang that is getting occasional erratic spark, I've replaced the whole distributor, plugs, and tested the coil, nothing has fixed the issue, looking for any other ideas of things to check
Sally91 is offline
Old 12-10-2013, 10:20 AM
BabyGT
BabyGT's Avatar
When does this happen? Cold or hot or just one or the other. Often times a coil going bad will only act up when the engine is hot. So testing it won't always show if it's bad or not.
Pick up a cheap coil, swap it out. If that's not the problem just take it back and say you never needed it. They won't know.
BabyGT is offline
Old 12-11-2013, 08:45 AM
88 orangepeel notch
88 orangepeel notch's Avatar
This is a shot in the dark, but my car was giving me all sorts of electrical and running problems. Ended up being a bad ground connection from the neg. cable on the block. Cleaned that up and night and day difference. Just something to check. Mine looked good, and was tight, but after taking it off revealed po never took the paint off the block under the connection.
88 orangepeel notch is offline
Old 12-11-2013, 11:06 AM
Roger Mabry
Roger Mabry's Avatar
Default Mine was bad coil wire connection at the coil
Just fixed mine that had the same symptoms. Coil is mounted on fender well and the wire goes across to the top of the coil. The metal connection was too
large and it suffered under any load...easy to fix - bend the connector with a pair of pliers until VERY tight - lube and put back on.
Roger Mabry is offline
Old 12-12-2013, 03:45 AM
Sally91
Sally91's Avatar
I've checked and cleaned both the pos and neg connections, that didn't change anything, the car won't start regardless of temperature, but I have heard of a fusible link on the ignition circuit that could possibly be the issue?
Sally91 is offline
Old 12-12-2013, 04:31 AM
dawson1112
dawson1112's Avatar
So the car is not starting at all?
Im curious as to how you tested the coil.
dawson1112 is offline
Old 12-14-2013, 08:50 AM
Sally91
Sally91's Avatar
Correct, ive ohmed it, and checked power to it both are showing what they should
Sally91 is offline
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 90 5.0 erratic spark
