should have no issue unless you have high rise covers if so you need plenum spacers 1/2 -1" and the oil filler neck may be in back not front,i bought a crete motor and it came with the same as you have I cleaned and painted the old ones and they look better then what came with motor
if this is for your 90 gt with a 5.0 and you need a spacer or 2 I have 2 new ones I bought then switched over to a trick flow intake witch takes a trick flow spacer
