tremec transmission
Old 01-19-2014, 03:55 AM
dchallenger
dchallenger's Avatar
Default tremec transmission
found out my transmission is a tremec saw numbers 2606224 and 2605865 on the transmission...does anyone know which tremec model i have?
dchallenger is offline
Old 01-19-2014, 08:06 AM
dawson1112
dawson1112's Avatar
You need to find the tag that is located on the trans those numbers look like casting numbers to me.
There should be a tag on the drivers side of the trans mission .
dawson1112 is offline
Old 01-19-2014, 03:33 PM
dchallenger
e6zr-6394-a does that look like the number...
Old 01-19-2014, 08:18 PM
dawson1112
dawson1112's Avatar
That's the bell housing number.
there should be a metel tag that is bolted to the transmission , on drivers side , I think where the tail stock bolts up
Old 01-20-2014, 07:50 AM
dawson1112
dawson1112's Avatar
On the tag it should have a 1352-xxx on it the xxx numbers will identifiy what t5 it is, then if there is a Z after that it is a z spec or what they consider the tremec heavy duty t5. If I can get out to my car later and get a pic of my tag on mine ill post it here,
Mins is a z spec tremec t5.
Old 01-20-2014, 11:04 PM
dchallenger
found the tag on the passenger side....pulled it off...and it says tr 3550-1 AHUJE 13 2600694 0001
Old 01-21-2014, 04:25 AM
dawson1112
dawson1112's Avatar
Then that's what trans it is , Tremec Tr 3550.
Old 01-21-2014, 12:38 PM
dchallenger
thank you very much for your help
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: tremec transmission
