Compression Ratio??
Old 03-20-2014, 08:44 PM
andywhiting1990
andywhiting1990's Avatar
Default Compression Ratio??
I have 58CC aluminum heads
L2249N STD Bore Dome Pistons 10.4 CC DOME
Standard head gasket
1.72 roller Rockers
Duration 270/278, Lift .528/.533 Camshaft
Wondering what kind of compression ratio Im looking at everything else is standard....
I might go with the stock 5.0 ho flat top pistons... What would that same build give me with stock pistons instead of the dome?
andywhiting1990 is offline
Old 03-24-2014, 01:56 AM
tinman
tinman's Avatar
Need to also know exact deck height as well as exact head gasket thickness compressed to try to come up with an answer for this.......
tinman is offline
Jb145700
08-21-2022 06:37 AM
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
bconboy
09-21-2015 12:52 PM
uberstang1
09-20-2015 06:42 PM
Quick Reply: Compression Ratio??
