Car Won't Stay Running
Hi.
Went to take the 92 GT out for a spin last weekend and I couldn't get it to stay running.
When I turn the key on, you can hear what sounds like a sucking or blowing noise coming from around or behind the throttle body area. We spent 20+ minutes trying to pinpoint where it was coming from but couldn't find it. It makes that noise nonstop until you turn the key back off. When I actually tried starting the car, it would just crank and crank. I eventually got it to start a couple of times after giving it a bunch of gas, however it would not stay running at all unless I continued to give it continual gas. Even when I gave it gas to keep it running it was very rough and choppy and then the second I would let off the gas it would die again. Any ideas?
Here are a couple of mods around the area the blowing noise is coming from:
-BBK fuel rails and regulator
-39lb ford racing injectors with EV6 adapters
-GT40 tubular intake 1 inch spacer
-Accufab 70mm throttle body
Also, I don't really hear the fuel pump turn on when I turn the key. It's a Walbro 255 high pressure high volume fuel pump.
Thanks
Thanks
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
