5.0 Cobra engine and the 5.0
Old 10-15-2005, 04:47 PM
ReVz
ReVz's Avatar
Default 5.0 Cobra engine and the 5.0
What are the major differances between the regular 5.0 engine and the 5.0 Cobra engine?
ReVz is offline
Old 10-15-2005, 05:08 PM
Black Snake
Black Snake's Avatar
Default RE: 5.0 Cobra engine and the 5.0
Im just taking a shot at this but I think the Cobra engine have different, pistons, computer, injectors, intake, and tranny. As far as the block im preety sure they are the same. I think they might have 1.7 lifter though but im not sure. Did they have different heads anyone know?
Black Snake is offline
Old 10-15-2005, 07:22 PM
FoMoCo
FoMoCo's Avatar
I think they had gt40 heads. cobra is way different than the 5.0
FoMoCo is offline
Old 10-15-2005, 07:30 PM
grabbem88
grabbem88's Avatar
you guy's are pretty much right gt 40's crane 1.7's,intake,24lb inj.,mass air was a little bigger,t-body was a little bigger.
the tranny was junk!.,they had issues of breakage.,so supposedly they made the computer not as aggressive? which i think is boggus,cause why is the aftermarket chips,pms,ect. use it as a base line for start up programming?
grabbem88 is offline
Old 10-15-2005, 08:44 PM
Cobra Owner At 19
Cobra Owner At 19's Avatar
stock 94-95 cobra owners were stuck with the 60mm throttle body that the gts had, the 93 cobra had a 65 mm tb tho. The computer was not made as aggressive in cobra beacuse of the ROLLER ROCKER 1.7s, the stock gt's had non roller 1.6s so to make up for the extra lift the car recvived a less aggressive camshaft that makes the computer flip out sometimes with certain cams under a 112 LSA, and dont you ever belive that 240 hp rating on the pushrod cobras either, people are dynoing 232 at the wheels bone stock on these suckers, and multiple magazines have shown its more of a 270 ish rating. THe computer problem sucks tho cause your forced to tune more so then other when you do internal work. otherwise im happy with my 94 cobra.
Cobra Owner At 19 is offline
Old 10-15-2005, 09:32 PM
95whitecobra
95whitecobra's Avatar
The Cobra cam actually has more lift and duration than the stock Fox cam. I agree that the Cobra pcm is less aggressive for spark and fuel. Neither the 94-95 GT's pcm (T4MO) or 94-95 Cobra pcm (J4J1) likes h/c/i changes. This is because the programming is load based and not rpm based like Fox pcm (A9L). Does this make the A9L better or the Cobra computer sick. IMO the answer is NO! Look at this way the A9L is actually allowing modifications because it is not correctly adjusting for those mods. The load based pcm's are more sensitive (accurate) to airflow, spark & fuel changes.
The blocks are identical as is the TB and MAF.
95whitecobra is offline
Old 10-16-2005, 06:27 AM
Black Snake
Oh I thought he was just talking about the 93 fox Cobra, I dont know a thing about the sn95 cobras, maybe they are the same, but i donno.
Old 10-16-2005, 10:27 AM
Quik
Quik's Avatar
GT40 motor has a less aggressive camshaft. it gets it lift from the 1.7s
93 snake had a 70mm maf and 65mm tb
GT40 heads with 1.84/1.54 valves
Quik is offline
Old 10-17-2005, 04:31 PM
ReVz
ReVz's Avatar
So could I turn my 94 GT 5.0 into a cobra? or could I even make it better then what a cobra would do.. I have been looking into Kenne Bell S/C's
ReVz is offline
Old 10-17-2005, 09:41 PM
ReVz
ReVz's Avatar
geez.. no1 can answer my question?
ReVz is offline
Quick Reply: 5.0 Cobra engine and the 5.0
