IAC question
Old 09-07-2014, 12:09 PM
95gtconvert
95gtconvert's Avatar
Default IAC question
Mine is giving me trouble with how my car runs when it's in any gear other than park or neutral is there something I can do to clean it or do I have to replace it
95gtconvert is offline
Old 09-08-2014, 08:39 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Yes you can pull and clean them, and might as well clean the MAF sensor element with electrical contact cleaner.
88 orangepeel notch is offline
Old 09-08-2014, 04:37 PM
95gtconvert
its got the surge
tried cleaning it and its still having the surging where its dying off I'm not planning any motor swaping unless it's bigger than a 302
Old 09-09-2014, 06:43 AM
88 orangepeel notch
There are a ton of threads on "surging idle" in this forum. Do a search and you'll be reading for days. It is curable lol. Good luck
Old 09-10-2014, 03:54 PM
64bit
64bit's Avatar
if your engine is surging, your IAC is doing what it's supposed to. Try searching for vac leaks, and verify that your O2 sensors and ECT sensors/sending units are functioning correctly.
64bit is offline
Old 09-11-2014, 08:48 PM
95gtconvert
found that it's the egr valve making it surge so I'm getting a new one courtesy of my uncle and his buddy with getting parts discount
Old 09-12-2014, 07:13 AM
88 orangepeel notch
Glad to hear, so, you still going with a carb set up? I think your going to like the EFI a lot more when you get yours fixed. Good luck
Old 09-19-2014, 08:46 AM
95gtconvert
If I get it fixed and don't sell my 302 I'm planning to build over winter then yes I'm going to keep it and probably just go with a kenne-bell supercharger or a turbo setup or maybe just build it a bit cause stock isn't enough fun for me
I have the hose disconnected from the fuel pressure regulator to the egr and it runs so smooth but my only issue is when I slow down and take off it has a surge otherwise the motor is fixed
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: IAC question
