what is this thing?!?!?
Old 12-23-2014, 08:59 AM
  #21
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
scroll to post 7 in this link, it'll tell you what you have and how to use it.........it's the PIH harness instructions, by reading it and see if some of the mods were/were not done, may explain some of the issues you may/may not have:
http://forums.corral.net/forums/94-9...ox-re-pin.html
mjr46 is offline
Old 12-23-2014, 10:20 AM
  #22
9550
9550's Avatar
Originally Posted by mjr46
unless you see a chip sticking out of the j3 port on the end, you have no custom tune on it
this j3 port is visible in the pics i posted? or at least, would a chip be visible in the pics if it were there?
9550 is offline
Old 12-23-2014, 10:22 AM
  #23
9550
9550's Avatar
nice, thanks
i have a link bookmarked to this site was planning to investigate today, this saved me some time i think.
thanks!
9550 is offline
Old 12-23-2014, 01:59 PM
  #24
mjr46
mjr46's Avatar
on the end of the case, oppisite side of the harness end, there is a ford oem sticker that says do not remove or warranty void......or there is a plate with a screw covering the j3 port up, mine had the sticker over the plate, yours may just have the plate
mjr46 is offline
Old 12-24-2014, 04:29 PM
  #25
9550
9550's Avatar
ok thanks
i saw the do not remove sticker the other day. appears to be intact.
i guess if the sticker hasnt been removed, theres no chip, yes?
i will look once it stops raining
thanks again
9550 is offline
Old 12-24-2014, 08:38 PM
  #26
mjr46
mjr46's Avatar
ok thanks
thanks again
yup, most likely..........it's a unmolested eec iv
mjr46 is offline
Old 12-28-2014, 12:56 PM
  #27
96GT_Loud_Clean
96GT_Loud_Clean's Avatar
[QUOTE=dawson1112;8452413]With out knowing what the wires are tapped into, my best guess is its a DIY decade resistor box. It could be used for anything including tricking the PCM into thinking a sensor is there, to changing the resistance of sensors such as the IAT ECT etc etc.
The dials are there to set the amount of resistance while hooking up a mulimeter to read the changes.
It could be used for all kinds of different things, you just need to trace the wires to what they are connected too.
Oh and do not under any circumstances change the dials settings untill you know exactly what its hooked too. Ive seen similar boxes used with the old GM VATS security keys to get proper resistance to the computer so as to by pass the resistor in the key pellet.
Oh and 1 more thing, that box in the picture is the PCM and its not supposed to be under the seat, it should be in the passenger side kick panel.
They may have done some screwy stuff to your car who know. It looks to me to be a home made Chinese tuner lol
Haha! It's the key part to a V-Tec!
96GT_Loud_Clean is offline
KingRando
10-02-2015 08:06 AM
RCS02v6
09-29-2015 01:46 PM
GLOCKer
09-28-2015 07:36 AM
treesloth
09-28-2015 07:03 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: what is this thing?!?!?
