Car won't turn off
Old 02-11-2015, 06:45 PM
dart67eb
dart67eb's Avatar
Default Car won't turn off
The car won't turn off. When I go to the off position it feels loose and nothing happens. I pulled the fuel pump fuse and batt terminal to shut it off. It seems like the upper plastic slider is engaged but it is not pulling the lower slider that shuts off the ignition switch. Anybody run into this before?
dart67eb is offline
dart67eb
dart67eb's Avatar
95 Mustang GT convertible. 5.0 auto.
dart67eb is offline
Old 02-13-2015, 09:30 AM
HACKGT350
HACKGT350's Avatar
It sounds like the lock cylinder/tumbler in the column is bad
HACKGT350 is offline
Old 02-13-2015, 09:00 PM
95gt302
95gt302's Avatar
I had the same thing in my 95 gt I had to rebuild the column, there are metal rods inside that actuate the ignition switch and one fell out of place until I had that fixed I just pulled the switch down and used that to shut mine off
95gt302 is offline
Old 02-15-2015, 06:35 AM
64bit
64bit's Avatar
It's very common for those plastic rods to fail. Sounds like you've got to rebuild the column.
64bit is offline
Old 02-15-2015, 08:39 AM
bluebeastsrt
bluebeastsrt's Avatar
Ditto. Plastic rods failed in my column also. I fixed my problem by just swapping out the entire column with another. It was a $25 buck you pull piece.
bluebeastsrt is offline
MXBT187
08-20-2015 02:36 AM
KEM Motorworks
08-14-2015 10:13 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Car won't turn off
