A/C compressor and power steering bolts
Old 03-06-2015, 07:34 AM
yurizx6r
yurizx6r's Avatar
Default A/C compressor and power steering bolts
Hey guys, does anybody know what size and where I can get the bolts for the power steering pump and a/c compressor (besides the ones that go off the timing cover/water pump, I already have ARP there)?
yurizx6r is offline
Old 03-06-2015, 02:55 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Where they go into the head is either a 3/8"-16 or 7/16"-14 depending on the bolt hole. As far as the length goes im not totally sure since they vary. They should be around 1.5-2". The power steering bracket will be a long bolt. Possibly 4-5 inches. Best thing to do with that is measure it with a caliper/depth mic or take a guesstimate with a tape measure and screw driver.
Boss_Hotrod is offline
Old 03-08-2015, 02:18 PM
yurizx6r
yurizx6r's Avatar
I finally got the heads off and I pulled the bolts/studs off. I'm going to take them to a local Ace Hardware store to try to match them up. They probably still will work, but why not put new ones in there since everything is off. Especially since I'm putting in aluminum heads. I will write down those measurements. Thank you!
yurizx6r is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
BOBCATJACK
09-14-2015 02:18 AM
fastbackford351
09-12-2015 09:42 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
09-08-2015 11:50 AM
Quick Reply: A/C compressor and power steering bolts
