Engine Revving On Its Own (burning Out My Clutch!)
Old 04-18-2015, 07:07 AM
XDIME03
XDIME03's Avatar
Default Engine Revving On Its Own (burning Out My Clutch!)
Hello all. Any help would be appreciated. I have a 1992 LX 5.0. When I start cold runs great drives good. After I drive for 15 mins or so when I clutch the rpm's jump up to 2k. Then after it starts that if I shut the engine off and it may restart its ok for a few minutes. Sometimes it does not want to restart as if the battery was dead. After sitting and cooling for a few minutes it will start back up again. Seems like something is getting hot. I was told possible iac valve so I replaced it but same condition. Not sure where to go from here.
XDIME03 is offline
Old 04-18-2015, 08:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
perform a base idle reset, check for vaccum leaks above all......starter may be getting heat soak
mjr46 is offline
Nick Oliver
10-17-2018 04:22 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Engine Revving On Its Own (burning Out My Clutch!)
