built help
Old 09-13-2015, 08:22 PM
EASTIDEE123
EASTIDEE123's Avatar
Smile built help
Hey guys I wanted to ask some question about my swap . I have never built a motor and very excited to put this one together with the guidance of friends and family. I have recently purchased a 347 stroker with heads , cams everything to get the motor running . The head are comp heads I know they are not the best , but dont want to invest in this swap any more money . My question are the following what kind of injector should I run ?what kind of hp im looing at ?and with this set up is it necessary to purchased a canton deep oil pan . I ask because the car that the motor is going into is a bmw and is lowered to the ground .I will post motor spec .
comp cam valve lift @ .579 valave timing open @ .006 duration @ .050 236 lobe lift .3620 lobe separation 114.0
comp head 210cc heads were sent and rebuilt with non magnetic stainless steal valve (2.02 intake 1.60 exhaust double spring with dampers )
rotating assembly from eagle cast steal crank , Sir I beams and speed pro flat top forged piston with coated skirts .
Thanks guys .
EASTIDEE123 is offline
Old 09-13-2015, 08:47 PM
67LimeCoupe
67LimeCoupe's Avatar
Default built help
Thanks guys .
What kind of BMW?
67LimeCoupe is offline
Old 09-13-2015, 09:06 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
where to start with that mess of a combo...................???
mjr46 is offline
Old 09-13-2015, 09:50 PM
EASTIDEE123
its a e46 323i
Old 09-14-2015, 07:34 AM
88 orangepeel notch
88 orangepeel notch's Avatar
We're going to need a complete list of all engine components to give a accurate "guess" on power. Intake, exhaust, etc, etc.
But for now, anywhere from 250 - 450 at the crank.
88 orangepeel notch is offline
Old 09-14-2015, 08:56 AM
EASTIDEE123
I haven't bought the intake yet I was thinking about getting a holly systematic 2 .
Old 09-14-2015, 09:02 AM
88 orangepeel notch
OK, with the Holley, my guess goes up to 300 - 450 lol. It's a good intake with a solid reputation.
Old 09-14-2015, 09:04 AM
EASTIDEE123
Old 09-14-2015, 09:45 AM
EASTIDEE123
Thanks for the info buddy . Would I need to purchase a deep canton oil pan ? It is something that is a must ? And I forgot to mention I also have a high energy roller rockers 1.6
Old 09-14-2015, 10:32 AM
67LimeCoupe
Default built help
What will this car be used for?
Quick Reply: built help
