Tick tick no start help!!!!
Old 11-21-2015, 10:04 PM
Jly154
Jly154's Avatar
Default Tick tick no start help!!!!
Hey guys so I'm having an issue with my 94 gt not staring all of the sudden it just started going tick tick from under the hood it sounds like it's coming from around the alternator and the second tick following from around the intake manifold and every time it ticks the cel flashes but when I turn the ignition switch on it stops but no lights come on its just like the keys aren't even in the ignition and I'd off I'm at a loss I can't think of anything any help at all is appreciated
Jly154 is offline
Old 11-21-2015, 10:27 PM
Urambo Tauro
Urambo Tauro's Avatar
Start by checking your cables and connections.
Something could also be draining the battery, or it may not be getting a sufficient charge from the alternator. Even the battery itself could be faulty.
You can check for amp-draw and charging voltage with a multimeter. The battery, however, should be load-tested. Your local auto parts store can do that for you at no cost.
Urambo Tauro is offline
Old 11-21-2015, 10:58 PM
Jly154
Jly154's Avatar
Connections are tight ive tried putting my battery charger on it I've tried jump starting tried a different battery so idk do these cars by chance need a transponder key? When I bought it like three weeks ago on my way home with it it stated dinging like a door dinger so I got ahold of previous owner and he said it was because the key that I have is not a transponder key and it's supposed to have one. I have yet to put my multimeter on alternator but my guess it isn't that sense it won't start with jumping or charging?
Jly154 is offline
Old 11-21-2015, 11:04 PM
Jly154
Jly154's Avatar
I should have clearafied it ticks without the keys on or even in the ignition I'll unplug the ground connection and plug back in and it goes right back to ticking about every two seconds
Jly154 is offline
Old 11-22-2015, 11:41 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check starter selonoid
mjr46 is offline
Old 11-22-2015, 11:45 AM
Jly154
Jly154's Avatar
Well that was my second tought but I have no idea where it's at lol
Jly154 is offline
Old 11-22-2015, 03:35 PM
Jly154
Jly154's Avatar
And when the keys are out of ignition with ignition off and the car making the clicking sound
the oil pressure and temp gauge move all the way to the right
Jly154 is offline
Old 11-22-2015, 04:53 PM
Jly154
Jly154's Avatar
So update I checked starter relay and it seems to be good all my other fuses are good when I unplug the fuse to the fuel pump the ticking quits then I turn the ignition on all my lights come on but radio stays off when I turn the ignition on it won't start I turn the ignition switch off and the ticking comes back and it still won't start
Jly154 is offline
Old 11-23-2015, 08:10 AM
88 orangepeel notch
88 orangepeel notch's Avatar
If you keep quoting yourself, nobody's going to answer you lol.....
If your battery is good, meaning passes a load test and fully charged, I'd start looking at the cables and connections. When my car had similar problems, it turned out to be a bad ground connection. The neg. cable to the block connection was loose and corroded. Gave it a good cleaning down to bare metal, and all problems disappeared.
88 orangepeel notch is offline
Old 11-23-2015, 11:02 AM
Jly154
Jly154's Avatar
Ok well I gotta make ramps or buy them lol I asked my dad if maybe a bad grounding could be causing it and he said he didn't think that wa stage problem so I went out and bought a new starter solenoid oh well Ill give cleaning all my grounds s try and see if that works and if not I'll try the solenoide
Jly154 is offline
Quick Reply: Tick tick no start help!!!!
