GT40P swap
Old 05-25-2016, 09:00 AM
mikesr4565
mikesr4565's Avatar
Default GT40P swap
im getting ready to install GT40P heads on my fox with 1.7 rockers. my question is will there be a great improvement once it is done? will it be noticeable?
mikesr4565 is offline
Old 05-25-2016, 09:12 AM
dawson1112
dawson1112's Avatar
There will be a slight but noticeable gain. Your adding about 20 hp or so maybe.
dawson1112 is offline
Old 05-25-2016, 09:35 AM
mikesr4565
mikesr4565's Avatar
thank you for the quick reply
Old 05-26-2016, 01:52 PM
87 T TOP GT302
87 T TOP GT302's Avatar
Are the heads stock or have they been ported? Also what about intake and throttle body and exhaust as well ?
I'm asked because you will already have to remove these items to get heads off. Take it from someone who has done this before you don't want to do this often.
I put on the GT40's with 1.7 and then a couple years later took heads off had the exhaust ports gasket matched with new valve springs and cam.
You may feel a little difference but if your other components are changed you will feel more.
87 T TOP GT302 is offline
Old 05-27-2016, 07:10 AM
mikesr4565
mikesr4565's Avatar
I ported the heads and gasket matched them. I am putting Trick Flow valve spring upgrade kit on them. I have a cobra intake with a bbk70 mm throttle body, 24lb injectors, bbk shorty headers, bbk h pipe, A9L computer with the 4 bank eliminator chip, converted to MAF, 3.73's in the rear
Old 05-27-2016, 09:37 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Sounds like it's going to be a fun car. Keep us posted on the progress.
88 orangepeel notch is offline
ErdricK
5.0L V8 Technical Discussions
05-21-2016 04:26 PM
bduduk1@gmail.com
05-19-2016 12:22 PM
paul_g
05-17-2016 07:58 AM
rydahog
3.7L V6 Technical Discussions
05-08-2016 09:46 AM
Quick Reply: GT40P swap
