Upgrading My Alternator
Old 01-02-2004, 03:00 AM
Stang Chik
Stang Chik's Avatar
Default Upgrading My Alternator
Hey.. just wondering if somebody could tell me if I upgrade my alternator if I would need a different bracket or any thing else. Thanks!
Stang Chik is offline
Old 01-02-2004, 03:04 AM
TheGmKiller331
I ♥ Acer
TheGmKiller331's Avatar
Depends on if you go aftermarket or factory.I used a 100 amp alternator off a lincoln lsc and when i swapped it i had to use the bracket off the lincoln.</P>
Im pretty sure you can get an aftermarket alternator thats high output to fit in the stock bracket.If not universal brackets arent much to install or to buy.</P>
</P>
What year of stang is this on?And what do you need an upgrade to accomplish?</P>
TheGmKiller331 is offline
Old 01-02-2004, 03:13 AM
BLKSTANG9879
BLKSTANG9879's Avatar
If your getting a after market alt. It should say if it will bolt right up. Or if it doesn't it should come with the bracket that you need.</P>
BLKSTANG9879 is offline
Old 01-02-2004, 05:07 AM
mcgyver8062
mcgyver8062's Avatar
You should be able to go into your local Advance Auto or Auto Zone and tell them you want a larger amperage alternator for your ride, you need to know what amp you already have so you can make sure they don't sell you the same thing you have. (No mods necessary if you go this route) if you get one off of something else you will probably have to add brackets.<IMG src=smileys/smiley1.gif border="0"></P>
mcgyver8062 is offline
Old 01-02-2004, 10:12 AM
n2o44
n2o44's Avatar
i used powermaster , but a lil pricy , or do swaps like said <IMG src=smileys/smiley17.gif border="0">
n2o44 is offline
Old 01-02-2004, 04:27 PM
mkspeed26
mkspeed26's Avatar
i f*ckin hate electronics. www.summitracing.comhas a bunch of em
mkspeed26 is offline
Old 01-02-2004, 09:22 PM
ECR5.0
ECR5.0's Avatar
i have a 1990 and swapped my alternator with a 140amp out of a newer mustang (i think it was a 94 or 95). It doesnt bolt right up, you have to grind out the bracket a little. Its pretty easy, then just make sure you get the plugs that go with the alt so you can hook it up. Good Luck
ECR5.0 is offline
Old 01-02-2004, 10:03 PM
vfast
I ♥ Acer
vfast's Avatar
you could have grinded a lil on the hub where the bolt goes thru
I just used a 93 cobra alt because it has and overdrive pulley on it
vfast is offline
Old 01-03-2004, 01:53 AM
Pitviper100
Pitviper100's Avatar
what does a bigger alt accomplish i never understood that...
Pitviper100 is offline
Old 01-03-2004, 02:37 AM
TheGmKiller331
I ♥ Acer
More power is what it accomplishes.Its an absolute must for vehicles with electric fans,high powered audio/video setups,high powered ignitions and anything else you can think of that would go in a car.</P>
</P>
I used the lincoln lsc alt because it is used on a vehicle that already uses an electric fan and all the other options the lincoln has and handles it fine.In fact i traded the janky old alternator in and threw 30 bucks down on a brand new one and this thing is stout.Only thing that may suck for any of you that do this swap is wiring up the external regulator.It was a bitch since i was starting from scratch and had pulled everything from a junkyard.Just remember to use all new wiring to save yourself from wiring gremlins.And 4 gauge at the minumum is a must.</P>
Quick Reply: Upgrading My Alternator
