oil pressure
oil pressure
Hahah so here it is..
ok so i have an oil pressure problem.. i had a shop tell me that it was my oil pump and that a new oil pump would solve my problems. Well, two weeks ago they finaly convinced me that the pump was the problem and it would be all fixed and done with.. well, i wasnt sure that the pump was the problem so i told them i wanted the problem fixed and that i wanted a guarentee.. so i payed 65$ for them to diagnose the problem and 500 sumthen for them to do the oil pump.. well sure enough a day or two later im still having oil pressure drop off when i step on the pedal... well i come to find out they say they have checked the pressure but then told me that their mechanical guage was missing parts so i have to wait a few days for them to get the parts..(they found out that they were missing when going to check my oil pressure) so now ive been babying this damn car for two weeks trying to keep the oil pressure up..
what do i do.. im completely lost, im 18, this is my first mustang and i seemingly cant pay to have it fixed.. now im worried about ruining the whole engine! arrghh this sucks.. any help would be great..
before i had this fixed i posted a few questions and had no answers that would solve my problem other than good luck.. so i need some help here.. i kno you guys know what your talking about.
thnx bill M
thnx bill M
RE: oil pressure
my Notch oil psi jumps around. ive seen it under load drop some then rise. my car also has a few oil leaks and if you ahve leaks it wont hold good enough psi. if its only leaks fix them and your fine.
now if you do lose oil psi totally the well its too late and motor is junk
RE: oil pressure
my oil pressure is dropping.. it drops down very low but comes right back when i let off on the throttle.
i can drive it and have the oil pressure stay in good range but i have to baby it.
RE: oil pressure
Are you going by the stock guage or a good aftermarket?
Things to check:
1. the friggin guage
2. is there any oil in it?
3. take the filter off and cut it open(use tin snips or a cutter..not a hacksaw!)...see whats inside..your looking for chunks of metal or copper.
If there is oil in it, and you have 0 pressure it is phucked.
You said you just paid almost $600 to have the pump changed......I'm in the wrong line of work.
I didn't see your other "oil pressure" threads or I would have replied to them... I just went thru a ton of oil pressure problems.
Things to check:
RE: oil pressure
It could be the oil pressure sending unit. wiggle the wire on the unit and see if it affects the gage reading. I thought I had no oil pressure and I fiddled with the wires and magically my pressure went back to normal. It's common for the sending unit to go bad. They're cheap and easy to replace.
RE: oil pressure
yes yes. those stock sending units can go bad at any time. check your wires. go to an after market gauge if you want to. either way, the gauge is where i would start. You would here some bad noises coming from your car if you truly had 0 pressure or low. I know when I 1st got my heads on, my stock pressure gauge was going crazy....
otherwise....watch your oil. 600 bucks, nice! they really took you for a ride. did you go to the dealer?
peace!
peace!
RE: oil pressure
ORIGINAL: Quik
