347 stroker kit
Old 01-18-2004, 01:34 PM
5spd302
5spd302's Avatar
Default 347 stroker kit
i am thinking about buying this 347 stroker kit here is wut all is listed with it.</P>
a New 347 Ford Stroker kit, it comes with Keith Black Flat top pistons and HASTINGS MOLY rings. Along with CLEVITE rod and main bearings, a mellings HV oil pump, a complete gasket set, you choice of the cams listed below, a set of Hyd. flat tappet lifters, Dura bond cam bearings, brass freeze plugs, a 3 piece timing set (roller), a set of valve springs, 1.460 dia that are good to 550 lift, as well as retainers and 7 degree keepers, as well as a set of PBM forged connecting rods and a PBM 75,000 series crank. This kit is good to 550+ hp and should make on average with good heads 500hp or so. Cam choices #11006 with 208/208 dur at 50 with .448/.448 lift with 111 cen, #11008 with 204/214 dur at 50 with .448/.472 lift and 112 cen, #11012 with 218/224 dur at 50 with .458/.475 lift and 110 cen, #11014 with 214/224 dur at 50 with .470/,495 lift and 112 cen, #11016 with 218/218 dur at 50 with .460/.460 lift and 113 cen, #11020 .496/.520 lift and 112 cen, #11022 with 230/230 dur at 50 with .512/.512 lift and 109 cen. Pistons are available in std,.030,.040,.060 over winners choice. Just tell me which one of these you want with your kit and I'll send it</P>
i wanted to kno which cam and piston bore i should get and if i will probaly actually get around the estimated 500hp the kit claims</P>
5spd302 is offline
Old 01-18-2004, 01:39 PM
mkspeed26
mkspeed26's Avatar
if the block you are using is old, i would bore it .030 over to clean the block up and if you did that you would get the .030 over kit. for the cam, it all depends on where you want the power.
mkspeed26 is offline
Old 01-18-2004, 01:42 PM
vfast
I ♥ Acer
vfast's Avatar
well first I would look else where for the kit such as x2c,dss,probe etc....ok a few suggestion on the 347..one is they tend to not last long as far as mileage..also I have exp. rods breaking lately because of the pistons with there small contact area..on the other hand they make great power..but I tend to send people to be 331 which is a great engine...in order to get 500hp you will need a deep pocket so to speak with either a s/c, turbo or nitrous..a N/A 331 or 347 would hardly be streetable...a set of afr 185's would need to be had with alot of attention in the bowl area..none of those cam will get you in a 500hp rating unless with a power adder.. the 500hp seems to be throw'd aroung like it's nothing but is hard to obtain and make it streetable to have fun with<img border="0" src=smileys/smiley16.gif border="0">
vfast is offline
Old 01-18-2004, 01:57 PM
mkspeed26
mkspeed26's Avatar
is it a DD???
Old 01-18-2004, 01:59 PM
5spd302
5spd302's Avatar
ok so i take it the 347 is highly unreliable, i might just take my 302 the way it is now and dump about 150hp of nitrous into it for kicks and giggles when i need them<IMG src=smileys/smiley4.gif border="0"> or is there any other suggestions on wut i should do to get some decent power increase from my engine
5spd302 is offline
Old 01-18-2004, 02:03 PM
mkspeed26
mkspeed26's Avatar
h/i/c will give you power that is always there!!!
Old 01-19-2004, 02:00 AM
yardbird
yardbird's Avatar
I would get a 351w block and stroke it to a 377+ c.i. forat least400+hp then add a power adder for more. 351w blocks are much stronger than 302 blocks.dont get me wrong 302's can take abuse but a 351 is beefier.And dss makes a great girdle to make it handle even more!</P>
</P>
yardbird is offline
Old 01-19-2004, 04:11 PM
mkspeed26
mkspeed26's Avatar
if you buy the h/i/c/etc they will work on a 347 stroker if you want to stroke it later on when it isnt a dd. so i would get the h/i/c/etc first. they will give you more power too.</P>
Old 01-21-2004, 07:49 PM
5spd302
5spd302's Avatar
sorry this prob sounds extremely stupid but wut the hell is h/i/c ? lmao
5spd302 is offline
Old 01-21-2004, 09:06 PM
vfast
I ♥ Acer
vfast's Avatar
5SPD...go for the 331 you won't be disappointed....and you can still put a 150 shot on it...we have one with a 300 shot on it...
vfast is offline
Quick Reply: 347 stroker kit
