Non-5.0 question for the techs
Old 09-17-2007, 11:28 PM
Maxwelhse
Maxwelhse's Avatar
Default Non-5.0 question for the techs
Sorry for the non-5.0 question, but my daily beater has a problem...
1998 2.2L S-10... I went to do the crank trigger tonight and the damn thing busted off at the head and is now stuck in the block. I searched the S10 forums some and found all sorts of recommendations. I already tried running a screw into it and yanking with a pry bar... Tomorrow I'm going to try the same thing with a slide hammer.
Any other thoughts?
Maxwelhse is offline
Old 09-17-2007, 11:30 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: Non-5.0 question for the techs
idk which forum u used but my buddy uses www.s10forum.com not s10fourms cause he says it suck but idk but i do know the 2.2 is a ****ty enging with head gasket problems
rmodel65 is offline
Old 09-18-2007, 12:11 AM
dimebag
dimebag's Avatar
im not sure what u mean... wanna explain what happened? or whats stuck? if so... ill be able to help
dimebag is offline
Old 09-18-2007, 12:19 AM
mattdel
mattdel's Avatar
crank position sensor? maybe? i dunno
far as i knew, the 2.2 used a balancer mounted relucter ring
mattdel is offline
Old 09-18-2007, 07:07 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if it has a crank sensor in the block ...drill a hole and use a easy out and spray some PB BLASTER around it....PB blaster putd the harry home owner WD -40[:'(] to shame!!!
mjr46 is offline
Old 09-18-2007, 11:09 AM
Maxwelhse
Maxwelhse's Avatar
It's pretty tough to get a drill in down to it. I suppose if all else fails I'll have the hole the drywall screw left to try to use.
Thanks.
edit:
Dime: The head of it snapped off and left the remainder in the block, stuck to all hell.
matt: Yes... Crank position sensor, and on an S10 2.2 it is mounted directly below the coil packs (passenger side on the bottom of the block)
Old 09-18-2007, 02:28 PM
Hung Like a Stang
Hung Like a Stang's Avatar
might think this is a dumb idea, but you might try a powerful magnent to put up against the sensor and see if that'll pull it out. I know wal-mart has really powerful underwater magnents in the boating section that are cheap....just an idea.
Hung Like a Stang is offline
Old 09-18-2007, 09:04 PM
Maxwelhse
Maxwelhse's Avatar
ORIGINAL: Hung Like a Stang
It's plastic...
Old 09-18-2007, 10:50 PM
Hung Like a Stang
its got a plastic case.
There is a magnent inside the plastic which is rather powerful, Its a variable reluctive sensor which creates AC voltage.
thats why I think I'd at least try it.
Old 09-18-2007, 10:55 PM
dimebag
dimebag's Avatar
sounds like your going to have to drill it out... not much more choice, unless you have some left to get vise grips or something on...
dimebag is offline
Quick Reply: Non-5.0 question for the techs
