Broken floor pan/seat bracket
My seat bracket is broken on the drivers side (rear left) and the front left of the bracket has torn the bolt hole out of the floor pan on the mound there. Is there a replacement piece that can get welded in or do I have to replace the whole floor pan? Is there a stronger seat bracket I can get as well?
RE: Broken floor pan/seat bracket
ha mine is exactly like yours. for now i just have my rear seat folded down and against the front seat to keep it from rocking back and forth. your gunna have to get a sheet of metal and weld it to the cross beem in the front and put a bolt throught it to hold the front down as for the back just replace seat bracket
Thats what I was thinking. Im hoping theres a replacement patch piece out there I cant find.
Also something that is helping my seat from rocking; 3, 5 lb weights. 1 in front and two stacked on the back.
ORIGINAL: mjr46
they make reinforcement panels..50resto.com....check them out and I just welded the crack in my floor pan when it did that
ORIGINAL: Slo5oh
It pulled a nice clean hole rather than a crack
ORIGINAL: mjr46
ORIGINAL: mjr46
so go down to your local metal/welding shop and get a thin piece of cold rolled steel and make a plate.. that's what I did on my 84 bronco II
ORIGINAL: Slo5oh
ORIGINAL: mjr46
oh and...
mine was the same way also and after i got a different bracket from the bone yard, i stopped at my local hardware store and bought a bolt, nut, and oversized washers. i made sure the bolt was just barely long enough to not have too much extra and drilled the hole through the bottom of the floorpan. i know its a fairly ghetto way of doing it, but it cost less than $5 altogether and about 10 min of time and know my seat is fermly planted to the floor.
