need advice and opinions on performance
Old 12-31-2008, 09:13 PM
1987mach1
1987mach1's Avatar
Default need advice and opinions on performance
(that's what she said), anyways, in my tag, you can see pretty much what my mustang has, and i was wondering how this sounds to anyone that's interested (as far as if i should go with this route)
bbk equal length shorties
bbk o/r h
dumped exhaust at the rear axel
patriot heads (with the exhaust already ported)
gt-40x upper and lower intake (is the bbk upper better?)
and a 306 stroker kit
if anyone has an opinion on how they would do thing different, and what stroker kit you would go with (or if you think other brands for the parts i listed are better) please respond, thanks
1987mach1 is offline
Old 12-31-2008, 09:28 PM
Slowstang357
Slowstang357's Avatar
you can only bore out the cylinder .030 over to a 306..
Slowstang357 is offline
Old 12-31-2008, 09:33 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
not true.....you can go .040 and .060 on a stock block......anyway to the OP Patriot heads are less than desirable and the gt-40 intake only has looks going for itself nowadays with all the better performing intakes on the market
mjr46 is offline
Old 12-31-2008, 09:49 PM
Slowstang357
^yeah i know, but i meant that as in a 306 would be bored out cylinders not a stroker kit..
Old 12-31-2008, 10:16 PM
mjr46
mjr46's Avatar
^^^ ahh okay
mjr46 is offline
Old 01-01-2009, 12:07 AM
limp1969
limp1969's Avatar
why not get the holley top end kit or the trick flow? They claim 350 hp at the crank and its $200. Comes with upper lower intake, heads, cam, etc to do the job? I have a friend that has it and its good. Here is a thread to look at.
http://forums.stangnet.com/267821-ho...me-choose.html
limp1969 is offline
Old 01-01-2009, 12:59 AM
Explosive
Moderator
Explosive's Avatar
Your sig says E cams, it's an E cam, only one. You have pushrods, be proud of them
Might want tail pipes depending on what mufflers you get.
Explosive is offline
firecoyote
09-27-2015 02:37 PM
Mr. D
09-17-2015 08:17 AM
Pyrate Dave
09-10-2015 07:30 PM
09-08-2015 11:50 AM
Quick Reply: need advice and opinions on performance
