I looked and looked and looked for a vacuum leak with carb cleaner. It ended up being a bad connection on the ect sensor. Run the wiggle test and see what pops up. You may even find a vacuum leak if your lucky.
i found this on another site. i might try to make this.
You could do that, watch the psi you put into it. My smoke machine can run at a minimum of 50psi and usually turn the air pressure down to that because if it is to high it can push some vacuum hoses off.
can someone please tell me more of this smoke test from shops? i know people who blow cigarette smoke to find leaks but never heard of a machine that does it?!? any links
