Tubular K-member reviews wanted
Old 05-02-2009, 08:39 AM
psuhillbilly150
psuhillbilly150's Avatar
Default Tubular K-member reviews wanted
I am looking for reviews from people who have purchased and installed tubular k-members with any options coilovers/noncoilovers, tubular a arms or stock ones it doesn't matter I would like to hear about your experiances with them. Did anything get in the way like bigger oil pans or did you find any incompatibilities with other aftermarket parts? I want as much info as you can give me on any kit.
If I decide to purchase a k-member I will be running coilovers in the front which means I will most likely purchase a set of tubular a-arms.
Some information about my car:
I have a 351w stroked to a 408 running the hooker super comp headers which right now are extreamly tight. I have a canton deep sump oil pan that is going on. The car has a T-5 tranny (astro gears and imput shaft). I have done the SN95 spindle swap and am using the 13" rotors and dual piston PBR brakes. I will be installing a flaming river manual stearing rack and an aerospace engineering manual brake kit when I am ripping and tearing on the frontend.
Thanks guys.
psuhillbilly150 is offline
Old 05-02-2009, 12:41 PM
redpony88
redpony88's Avatar
i had no issues what so ever. as a mater of fact i gained so much clearance, the tubular k is Worth it by all means
redpony88 is offline
Old 05-02-2009, 01:06 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the k-member will open up the area , I have a d&d set up, works well , been in for 3 years.
mjr46 is offline
Old 05-02-2009, 01:38 PM
psuhillbilly150
redpony what brand kit did you use?
Old 05-02-2009, 02:17 PM
88BlueGT
88BlueGT's Avatar
I'm also running a D&D setup that works pretty well. Only thing you need to watch out for is with the headers. I have heard of people having problems with clearance with that kit... sounds weird because you would think that it would open it up so much but I have heard this numerous times from other people. I run a D&D K Member, D&D A Arms, UPR Coil Over. As for an oil pan, I run a 7qt Moroso and have no problems with clearance what so ever. Honestly, if I were to do it again, I would most likely go with a Team Z front setup.
88BlueGT is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
drfister
05-03-2018 10:38 PM
baron95
09-06-2015 09:24 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: Tubular K-member reviews wanted
