top end setup
top end setup
i am in the process of getting everything to rebuild most of my motor. i just want to put new rings on the pistons for now and put a set of AFR 165cc heads with a E303 cam, Trickflow street heat upper and lower intake, 70 mm throttlle body and possibly some new injectors.
any thoughts on this set up would be awesome.
i would get a 4 bolt main block if i could afford it, but i just want this to last until then.
Well since you're hauling out the pistons, it'd be a good time to change (atleast check) your main bearings and your oil pump as well. I know it adds up.. but a new thermostat wouldn't hurt either. Good luck!
thx for the suggestions so far. i/ve heard some of thos other cams run better in a 5.0 than the ford ones. im just tryin to not brak the bank. i'm goin to be doing this 5 months before my 30 k loan payments kick in
uberstang1
09-20-2015 06:42 PM
