Should I upgrade to 31 spline?
Old 07-26-2009, 03:09 AM
  #21
Liquid_02
Liquid_02's Avatar
Originally Posted by AdderMk2
NHRA rules are a bitch... I have 3" studs now
That's BS, you don't need 3" studs per NHRA rules, you can run an ordinary closed lug-nut if you feel like it. NHRA rule book (which I have read many times during my build) states the stud must protrude the hex portion of the nut a distance that is at least equal to the diameter of the stud. So for a 7/16" stud which your car has, the stud only needs to enter the hex portion of the stud 7/16" of an inch. Open nuts are to just make tech faster, they don't have to be open. I bought a set of ARP's, then cut them to fit under my closed lugs. Have never had a problem, they just make me take off a nut every time.
Liquid_02 is offline
Old 07-26-2009, 08:08 AM
  #22
AdderMk2
Banned
AdderMk2's Avatar
and on our FAST cars that run weld racing wheels... you need a 3" stud to get 7/16" of stud out past the hex.
dont **** with me
AdderMk2 is offline
Old 07-26-2009, 11:22 AM
  #23
Tony71502
Tony71502's Avatar
How can you run closed lug if it has to protrude that much? Do the threads in a closed lug end before the cap?
Tony71502 is offline
Old 07-26-2009, 04:56 PM
  #24
Liquid_02
Liquid_02's Avatar
Yes, the threads end before the cap, but 7/16" isn't very much, the stud doesn't even have to go to the end of the threads anyway, the hex portion on my nuts is an inch deep.
dont **** with me
Fast cars? You'd never even stand a chance of keeping up with mine with your 347 and 5 speed. I have a 408 w/ an auto, got rid of the 5-speed junk, if you did any true racing you would know 5-speeds are no good for it, ET is far too in-consistant, how many drag cars have a standard in them? Look next time. My car used to be a 5-speed car, but when I did the motor swap, got rid of that.
PaulH2
20
01-31-2016 09:48 AM
jrrhd73must
10-02-2015 09:17 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Should I upgrade to 31 spline?
