Free cam!
Old 09-16-2009, 07:15 AM
loeryder21
loeryder21's Avatar
Default Free cam!
I just got an e303 cam for free, my friend had it layin around... Think its really worth it to install it in a lightly modded 86? It might compliment the intake more and i plan on getting heads so a cam is definetly in my future but since i have this one already im curious as to whether or not i should stick with it.
loeryder21 is offline
Old 09-16-2009, 10:18 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
well if you have the stock 86 flat top pistons with no valve reliefs, checking for ptv will be a must and you may run into an issue, furthermore a cam swap requires a spring swap on heads
mjr46 is offline
Old 09-16-2009, 11:00 AM
w8less
w8less's Avatar
i think whoever gave it to you was just trying to move some junk out of their way
w8less is offline
Old 09-16-2009, 07:38 PM
mjr46
mjr46's Avatar
^^^first thing I did when I got this used 306 block was pull the e-cam and sell it
mjr46 is offline
Old 09-17-2009, 09:45 PM
OnyxCobra
OnyxCobra's Avatar
if you do use it wait to install it til you do the heads.
OnyxCobra is offline
Sixx
10-05-2015 07:36 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Free cam!
