__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
__________________
92lx frpp 5.0 gt40, vortech s-trim 14# Mighty mite m2 c4, Trickflow track heat, 4800 tct stall, 3.73 rear gears, true-trac, moser 31s,Wilwood drag brakes, strange 10-ways on all 4, weld prostars, M/T's & skinneys, Team Z Motorsports front k member kit and coilovers, eibach drag springs dual airbag
best Et-10.96
best mph 123.60 still got some in it. leaving it in the 60'
3145lbs with driver
Winter objective:10point,mini tub, team z rear suspesion, kirkley seats, 29.5x12.5 m/t et streets
5.0 kid..u suggesting he boost it as is...no other mods to the engine? What is s trim? Cause i got an 89 with only 57k on it. Should i just boost it and call it good? Maybe get a new 1mm cometic head gasket?
__________________ 400hp, 383 ftlbs KA-T S13.5 Nissan 240sx
GT3071r Turbo/264 Cams/8:1 Compression/Arias Pistons, Corillo Rods/550cc Injectors/ROM Tuned ECU/Apexi Neo SAFC/Full Exhaust/Walbro 255 pump 89 GT 5.0 Vert DD, mods on their way
On a stock engine a s/c might not be enough. S trim is a vortech unit. You may need the s-trim plus obvious bolt ons. I gt40 swap plus 1.7rr's and the s/c would be right around 400 I'd say
__________________
'95 Mustang GT- 347. Canfield 195's. Holley systemax. CI custom cam. 31 spline 8.8 w/ 4.10's. TKO 3550.
