347 build help?
Old 10-08-2009, 11:21 PM
hypertruejedi
hypertruejedi's Avatar
Question 347 build help?
I'm building a 347 over the next few weeks and I am aiming at around 400HP. I'm also wanting to do this for less than $4000 or close to it. I've picked out a couple kits that I like but I need a second opinion from some of my stang friends :P Does anyone know anything about either of these kits? (Do they fail, not fit on a 302, etc.) Or if this will even get me close to 400HP? http://www.summitracing.com/parts/EDL-2091/?image=large
http://www.summitracing.com/parts/CM...5/?image=large
thanks
hypertruejedi is offline
Old 10-08-2009, 11:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is your block a non roller or roller block??, if it's roller that kit won't work = for a flat tappet block
mjr46 is offline
Old 10-09-2009, 12:22 AM
mattdel
mattdel's Avatar
i'm wondering if summit would mix & match that kit a bit so you could get roller cam... HMMMM
my cogs are turnin.. thats a nice kit for the $
mattdel is offline
Old 10-09-2009, 12:29 AM
motorman524
MF Informant
motorman524's Avatar
you should check out fordstrokers.com as well. I stumbled across them when I was trying to decide on which way to go with my project.
motorman524 is offline
svfetter
10-05-2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-15-2015 11:08 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: 347 build help?
