Hey I need help setting up a budget for performance ignition I was thinking of running msd 6al box and coil need help for distributor from msd because there is the one that run off vaccum or on that plugs into the harness. Also what the heck is a crank trigger. Thanks in advance
Is this for an EFI engine? If so, you will need the distributor that plugs into your harness. If it is using a carb, its possible to use the TFI distributor, but the vacuum advance is what I would use.
