89 Mustang twisted uni body
you sure its the frame? you say the fronts stick out maybe the back is tweaked in..Especially if it was raced the rear may be tweaked check the torque box area and control arms and what not, rag joings simple stuff you dont wanna spend the money on strapping it down on a frame machine and payin the loot if thats not going to solve the problem.
Get under the car and take frame measurements. Measure in Xs For example tape measure tip on the lower ball joint passenger side and measure to the center frame section on the driver side of the car. Then go from the driver side ball joint to that same section point on the passenger side frame rail.
So ur measurements should be an X <- if the measurements are off. your going to need a frame pull if not thats not the problem.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
