Replaced Heater core, help!
Old 01-11-2010, 02:40 PM
1SVTLVR
1SVTLVR's Avatar
Default Replaced Heater core, help!
Ok, so I replaced the heater core and got everything back together, I got everything together and it seems to be fine but when I first start the car it beeps a very loud annoying beep 4 times and then repeats that about 3 times. What could this be? I don't have any errors or anything. Maybe I forgot to plug something in? Any thoughts on the beeps would be helpful.
1SVTLVR is offline
Old 01-11-2010, 02:46 PM
mattdel
mattdel's Avatar
Im on my phone so i cant see your sig or car info, but if its a 1990+ there is a blue box under the center vents that is the air bag diag module, it beeps like that when there is a fault in the system. if you dropped the column, recheck the wiring to it, or recheck the harness going to the module.
mattdel is offline
Old 01-11-2010, 02:58 PM
Tony71502
Tony71502's Avatar
Hey mattdel... does that blue box provide the turn signal chime as well? It sounds like it comes from the same area.
I'm getting ready to remove the box because my air bags are disabled... if the turn signal chime is from that box then oh well I can live without it.
Tony71502 is offline
Old 01-11-2010, 04:21 PM
mattdel
mattdel's Avatar
The door chime should be up under the dash on the drivers side, but could sound like its coming from that box.
mattdel is offline
Old 01-11-2010, 09:21 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
youve got something disconnected to the air bag sensor more than likely
rmodel65 is offline
Old 01-11-2010, 10:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that box only beeps like that if the cluster bulb is out for the air bag, turn the ignition key on, does the air bag light light up at all??
mjr46 is offline
Old 01-12-2010, 03:05 PM
RODRIGUEZ
RODRIGUEZ's Avatar
Yup, that sure is you're air bag control module.
RODRIGUEZ is offline
Old 01-12-2010, 03:07 PM
RODRIGUEZ
RODRIGUEZ's Avatar
I believe it is located rite behind the stereo, no need to pull the dash!
Old 04-15-2010, 02:33 AM
Donall
Donall's Avatar
That really cool to have that site...i will come back soon to see more in future as well
Donall is offline
Old 04-15-2010, 03:08 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
So how does a person get it to stop beeping all the time? My dad has been hinting me to getting his to quit
TrimDrip is offline
Quick Reply: Replaced Heater core, help!
