What Distributor and other recommendations???????
What Distributor for my new Ford Racing engine?
Going in a 1990 Ford Mustang GT
What other recommendations???????
I just purchased a Ford Racing engine m-6007-xefms,
Here is a some of my build.
1) BBK SSI intake.
2) BBK 70mm throttle body
3) Crane HI-6S CD Ignition and Coil Kit
4) Ford Racing 24lb M9593AA302 Fuel injectors
5) BBK 155LPH feul pump
Thanks for all the help.
Mark
1) BBK SSI intake.
Mark
Agreed the stock dis will be fine the only reason to change a distributor is if the old one broke, just like coils unless you like the new shiny metal and red parts, use the stock stuff the dis does just that puts a spark in a certain place at a certain time, a coil just sends the fire (on coils check the v output usually 45-48000 efi or the E coil), the blah budy blah about distributors and coils, unless you plan to see 7500-8000- 10000rpm or run in a class that has to be SFI approved stuff then go with what you have unless it is broken!
bradleyb
11-27-2015 07:50 PM
