Pinion Angle
Old 03-22-2010, 10:15 PM
motorman524
MF Informant
motorman524's Avatar
Just purchased adjustable uppers. Wish me luck
motorman524 is offline
Old 03-22-2010, 11:04 PM
5.0kid
5.0kid's Avatar
good luck with that man hope it solves it
5.0kid is offline
Old 03-23-2010, 08:40 AM
kweb288
kweb288's Avatar
very nice man! hows the trans working for you? along with everything else u bought from me haha
kweb288 is offline
Old 03-23-2010, 09:42 AM
motorman524
MF Informant
^Fraggin AMAZING man!!! I LOVE this transmission! When I the installed the k member and coilovers I also did Steeda superlites in the rear with new rear housing bushings and control arms(already installed subframe connectors). Launching improved by 100% over what it was previously. I put a PRO 5.0 shifter on it and swapped out the trans mount for a Lakewood poly mount as well.
Just need to get this vibration figures out so I don't break anything!
Old 03-23-2010, 09:58 AM
68CSTANG
68CSTANG's Avatar
This is going to sound dumb, but what type of vibration is it? Is it constant? Mine started having one like every 4-5 sec, and it would last about a second, almost like a rotating feeling, but not very fast. It started doing that after the first set of gears/control arms. I figured the DS was out of balance, but this thread got me thinking that it did't do that until I switched gears/control arms.
Anyhoo, maybe Ill see you at Midnight Madness if I get my junk back together. Good luck
68CSTANG is offline
Old 03-23-2010, 10:05 AM
motorman524
MF Informant
It is a real fine vibration that gets harder and harder and harder as you pick up speed. At 80 it is very bad.
Not gonna make Midnight madness this round. I have 2 bad injectors and I'm dealing with this(parts ordered).
I did gears a while back, before I did my control arms and before the manual trans swap. Didn't notice the vibration then.
Old 03-23-2010, 02:32 PM
67mustang302
67mustang302's Avatar
When you set the pinion angle remember that the diff and trans need to be equal and opposite. Meaning if the diff is set at -2, then the trans needs to be at +2. The reason is the DS does NOT rotate at a constant speed, the u joints generate an angular velocity that causes the DS to speed up then slow down, the speed up and slow down and so on. That means if the u joint angles at both ends are the same they speed up and slow down at the same rate...if they're not the same then each end of the driveshaft speeds up and slows down at a different rate, and it causes the DS to twist and untwist, generating a vibration. You can set the trans angle by simply shimming the trans mount, I use washers on mine.
Also keep in mind that ALL DS's vibrate to some degree, and the more gear you have the more it vibrates...but certain DS types vibrate less such as aluminum, then CM steel, then MMC and finally carbon fiber.
67mustang302 is offline
Old 03-23-2010, 05:24 PM
AdderMk2
Banned
AdderMk2's Avatar
wow, thats SOOO wrong
AdderMk2 is offline
Old 03-23-2010, 06:04 PM
5.0kid
5.0kid's Avatar
yeah about that im with adder
http://www.baselinesuspensions.com/info/pinionangle.htm
there ya go, and make sure its on a level surface
5.0kid is offline
Old 03-23-2010, 06:26 PM
AdderMk2
Banned
AdderMk2's Avatar
the pamphlet that I got frome baseline describes it a bit more "in depth" than their site... maybe one of these days i'll scan it and post it
AdderMk2 is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Gene K
10-21-2015 11:37 PM
KingRando
10-02-2015 08:06 AM
DJ Piner
09-30-2015 03:03 PM
Quick Reply: Pinion Angle
