Pinion Angle
Old 02-28-2010, 08:14 PM
motorman524
MF Informant
motorman524's Avatar
Default Pinion Angle
So I have been driving the car since I installed the new stuff and it has been awesome! The only problem is a TERRIBLE vibration that comes in at around 60 mph. Is this the pinion angle? How do I adjust it with non adjustable control arms?
(I put new control arms in a couple of weekends ago)
motorman524 is offline
Old 02-28-2010, 08:48 PM
AYEOH5.0
AYEOH5.0's Avatar
did you install gears? if so and they are higher then 3.55's i heard they will cause i vibration in the driveshaft if you still use the stock one because the shaft is spinning so fast.
AYEOH5.0 is offline
Old 02-28-2010, 08:54 PM
motorman524
MF Informant
Yeah I did a while back. 3.73's. There wasn't a vibration then but that was also before the manual conversion. So you don't think that the CA's could cause it?
Old 02-28-2010, 10:48 PM
AdderMk2
Banned
AdderMk2's Avatar
they very well could have... which is why (now that I know better) i will always suggest an adjustable upper control arm.
I bought non adjustables, and have been fighting a vibration ever since
AdderMk2 is offline
Old 02-28-2010, 10:55 PM
luckythirteen13
luckythirteen13's Avatar
probably a stupid question but when you installed the control arms, did you torque them down while the suspension was compressed?
whats the pinion angle now?
luckythirteen13 is offline
Old 03-01-2010, 06:27 AM
motorman524
MF Informant
No, I torqued them down while the car was raised in the air. I have no clue what the pinion angle is at right now. How in the world can they even sell non adjustables if this type of thing can happen?
Old 03-01-2010, 06:46 AM
5.0kid
5.0kid's Avatar
sounds like you need to hit on team z for some adjust-ables and put that pinion angle to -2* -3 for drag racing
5.0kid is offline
Old 03-01-2010, 01:34 PM
luckythirteen13
needs to be torqued down while the suspension is loaded. just jack it back up, put the rear end on jack stands and then retorque. might help, might not. if not, look into adjustable upper arms and like 5.0kid said, check out team z for pinion angle adjustment info
Old 03-01-2010, 01:57 PM
5.0kid
5.0kid's Avatar
I may have some old lakewood adjustables if you want to pay the shipping ill go take a look for them
5.0kid is offline
Old 03-01-2010, 04:25 PM
motorman524
MF Informant
YES, I'd love them if you can part with em. How much would you like for them? I'll pm you.
(trying to get this car ready for Midnight Madness at Gateway in March)
Quick Reply: Pinion Angle
