never used header gaskets on any of my rides....straight orange RTV silicone works great, as long as you let it cure overnight before starting the engine.
For a daily driver, Percy reuseable header gasket and stage eight stainless header bolts. Don't need threadlock. If you use threadlock compound there are various grades that break down at various temps. Stuff on the open market will not hold due to exhaust temps (need Aviation Grade). Then good luck later when you try to remove bolts, you will have to heat with torch to break down compound to remove bolts later. MAC
