Which rockers for this setup?
I'm about to install gt40p heads on my 88 with a comp cams stage one xe264hr cam. My question is what ratio rockers do I need. I am getting mixed opinions. Also, what kind of rockers should I get? And I believe that cam choice would compliment my heads nicely, correct? Thanks!
what are the specs on that cam ? i would say 1.7's unless the lift is too much
sometimes you get in a situation where you wanna do 1.6 on intake and 1.7 on exhaust
all depends on cam profile and what you need to tweak
Intake Exhaust Valve Lash: Hyd. Hyd. Duration: 264 270 Duration @ .050" Lift: 212 218 Valve Lift: 0.544 0.544 Lobe Lift: 0.321 0.321
Valve Timing @ 0.05" Lift: Open Close Intake: 24 BTDC 60 ABDC Exhaust: 71 BBDC 19 ATDC
Less hard to read specs here: http://www.americanmuscle.com/mustan...hr-stagei.html
