So what would be your advice(and everyone else's) as far as how much boost to run? I'm making 9.3:1 compression. (Dish pistons and 61cc cyl heads). I'm not gonna FI it anytime soon, don't have any $$$ saved up yet. Also havn't decided on turbo or S/C yet. But I think this may Help answer the O/P's question as well as mine.
depends on the setup i ran about the same compression as you i had crap *** gt40 heads a tfs street heat intake and a s trim at 16 psi non intercooled at 22 total timing at 6000 rpm made 474 to the rear wheels at 12psi and 36 total timing it was making according to mph and et around 650 at the crank which woulda been like 540 at the rear wheels.
It's really a toss up. My motor was making over 650 at the crank for a good 2 yeas n about 550 for another 2 n never failed. I just sold it recently its more about a good tune and luck. To the op you can make 500 hp with a standard 302 just gonna take a bit more boost
So with the right heads, cam, etc, setup can i get that kind of HP from a centrifugal style supercharger or would I have to go to the roots style, or does it make a difference?
Also... isnt running too much boost bad for the block anyways or does the concern have to do with strictly the amount of hp? would it not be safer for the block to go with a stroker kit and put a 6-8psi or lower s/c on? or am i just completely misinformed?
there is going to be a ton of different view points i would say cylinder pressure on a stock block can be a issue and forced induction tends to be very different from an N/A motor total compression not static compression is very different with a forced induction style motor. either way its really a difficult issue to say which is better. It would probably survive better at the 6-8psi range
a centri type is what i would go with vortech preferably. a roots is nice but will not make as much power as a centri (were not talking nhra style here ok people)
save up the extra $700 and get a DART SHP block honestly, then you wont have to worry about the stock block any more, itll come down to fuel system limitations and tuning issues...
either way i dunno why i even start thinking about doing something like this sometimes i forget i live in CA where smogging anything can be a nightmare with even mild mods done to your car...
