1995 bolt on questions///. not tech!!
Old 03-30-2011, 12:11 AM
NineFour5.0
NineFour5.0's Avatar
Default 1995 bolt on questions///. not tech!!
so now i got my stang running right, its time to bolt on, i placed orders for a full exhaust headers to tips, CAI , 75mm tb, UD pullies, .. i plan on putting a #19 steeda cam and holley system max intake, my question is would the cam be good for my car with 1.7 rr, and i plan on putting heads soon would the cam work well with a set of aluminum heads , and if so any suggestions on heads? and any other suggestions on getting me into the low 13's - high 12's w/o stroking or power adding??
NineFour5.0 is offline
Old 03-30-2011, 08:13 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
alum heads with that cam and a good suspension setup should AT LEAST get you into the 12's if not high 11's.
look into a better intake though and if it wont kill you maybe the TFS 2 cam
sn95_331_GT_ yellow is offline
Old 03-30-2011, 11:18 AM
Venomantidote95
Venomantidote95's Avatar
What heads and what are the cam specs? U wasted your money with a cai unless you bought a real one like c&l or anderson power pipe other than that your stock rubber was fine.
Venomantidote95 is offline
Old 03-30-2011, 11:24 AM
NineFour5.0
im not sure what heads im open to any suggestions??? so please give me some lol
cam specs :Steeda #19 - 220*/226* - 280*/286* - .480"/.480" - 115* - 2,300-6,000 RPM
im open to changing that also , honestly anything to get me to my goal.
Old 03-30-2011, 11:26 AM
NineFour5.0
so i should from the steeda #19 to the tfs 2? and any suggestions on some aluminum heads?... what intake is better than the holley?
Old 03-30-2011, 11:32 AM
Venomantidote95
The patriot sbf heads are impressive and cheap! Those the tfs stage2 and a decent intake will definatly help but you need gears if still stock!
Old 03-30-2011, 11:43 AM
NineFour5.0
oh ok im going to check the patriots out , so you think the tfs2 would be better than the steeda#19 cam, and what intake do you think would be good? would 3.55s be good, its gonna be driven regularly , sorry to be a nag im just excited lol
Old 03-30-2011, 12:32 PM
Venomantidote95
No nag man we all have questions! Yes the 19 is a tweaked bcam and most aluminum heads peak about. 550 lift. The smaller cans are targeted for a closer to stock head. Summit has the patriots for like 950$ fully assembled there basically Afr heads same ports and bigger intake vlv. I just used a set on a 306 fcam and oh no a stock intake in a 95 and it was very impressive to be so chocked off!
Old 03-30-2011, 05:48 PM
nitrous_bob
nitrous_bob's Avatar
no, 3.55 will feel stock to you
unless your gonna turbo or get a blower.......
do 3.73's if you get scared really easily
or 4.10's if you want the most out of your build
nitrous_bob is offline
Old 03-30-2011, 06:18 PM
Venomantidote95
Well I haven't ever felt a 3.55 that felt like a 2.73lol. There are more things to consider on gearing than feel! Your car stick or auto?
Quick Reply: 1995 bolt on questions///. not tech!!
