arp bolt help
Old 08-30-2011, 09:47 AM
g3mustang
g3mustang's Avatar
Default arp bolt help
on stock heads what head and intake bolts should buy??
http://www.summitracing.com/search/M...d+bolts&page=1
g3mustang is offline
Old 08-30-2011, 10:27 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
DEPENDS, if you want 12 point or 6 point heads on the bolts, either is fine, if this is for the s/c ride I'd do studs,why?? >>>>> clamp > bolt down
mjr46 is offline
Old 08-30-2011, 10:29 AM
g3mustang
g3mustang's Avatar
can i fit the studs with the master cylinder on the car or would i have to remove that too? also if i could find a used set of heads like some eddy aluminum or something would that make a difference on the studs/bolts..
p.s.i sold my s/c setup im going turbo!
Old 08-30-2011, 11:14 AM
uedlose
uedlose's Avatar
like said I would run studs also. I can remove the heads without pull the master and I run studs I have been doing it for years. But my engine mounts may be lower then yours. I do have a set of ARP bolts for sale if you are looking click on the like at the end of my sig. for the price LMK mine are the 6 point if I remember right
uedlose is offline
Old 08-30-2011, 11:23 AM
g3mustang
g3mustang's Avatar
prob go with studs then im looking at a set of gt40x heads used any difference in studs over stock heads?
Old 08-30-2011, 10:11 PM
tinman
tinman's Avatar
I also use the studs on mine and have no problem pulling the heads off with the brake cylinder still in the car.
You can call Summit ask them about your application. It's a 1-800 type number and they answer 24/7.....
tinman is offline
Old 08-31-2011, 07:02 AM
mjr46
mjr46's Avatar
you can screw the studs in after head is set, they have a allen head insert to do such, I just pulled my heads by doing such, and yeah I saw you on the corral in the turbo section iirc asking questions.....on3 set up should make and easy 450 rwhp, the kit I put on for a friend after a tune made 477/501, on a near stock set up with a few bolt ons, no worry about on3 the jokers over there like to bash them..lol
mjr46 is offline
Old 08-31-2011, 07:58 AM
AdderMk2
Banned
AdderMk2's Avatar
If I were you. I wouldn't run the ARP intake bolts. I am not the first person to have horrible luck with them galling up in the threads and breaking off.
Go to your local hardware store and you can buy some really nice grade 8 studs and nuts.
AdderMk2 is offline
Old 08-31-2011, 10:38 AM
g3mustang
g3mustang's Avatar
great thanks for all the help guys i did end up buying a used set of gt40x heads just cheap for right now they will be more then enough to split the block.
adder instead of running bolts you say i should run studs on the intake too?
Old 08-31-2011, 10:53 AM
g3mustang
g3mustang's Avatar
last question on gt40x heads what intake gasket do it get? im going to run that can field intake just b/c i love the way it looks lol
Quick Reply: arp bolt help
