turbo 306 or 347?
Old 09-21-2011, 09:50 PM
5.0fiend
5.0fiend's Avatar
477 huh...cant wait
5.0fiend is offline
Old 09-22-2011, 11:39 PM
tinman
tinman's Avatar
If the engine is turbo'd it will need some support type mods if it's going to survive very.
IMHO, there will be somewhat of a larger total cost involved doing than if you just built a 347.
Think of the cost of a good rotating assembly, not the one advertised for $899.....
Thats only the starter item.....
tinman is offline
Old 09-23-2011, 08:24 PM
5.0fiend
5.0fiend's Avatar
im thinking about the ford racing 306, im not worried about the cost im ready to spend 6-7k
5.0fiend is offline
Old 09-29-2011, 12:25 PM
w8less
w8less's Avatar
Originally Posted by AdderMk2
use a traditional air to air intercooler.
you can do both. i know a lot of the turbo 4cyl guys do both to run a little more boost and timing
w8less is offline
Old 09-29-2011, 09:53 PM
NoGo95GT
NoGo95GT's Avatar
Stroke it...Then blow it!
NoGo95GT is offline
Old 10-02-2011, 12:22 PM
kweb288
kweb288's Avatar
if you stroke it, then blow it, jsut make sure to use an aftermarket block so you dont split the stock on and pi$$ away money.
also you should head over to http://turbomustangs.com
and check out some of the guys stuff over there on the build forums
kweb288 is offline
TCStangerv6
10-11-2015 05:57 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-15-2015 11:08 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Quick Reply: turbo 306 or 347?
